Mark Taylor Posted August 29, 2013 Share Posted August 29, 2013 Very simple: I want to draw a circle, like a tree trunk, using data from the site notes with a center position and a circumference. Quote Link to comment
M5d Posted August 29, 2013 Share Posted August 29, 2013 You could also add a request to the wish list, for the circle perimeter data in the OIP to be an editable field. Quote Link to comment
Kevin McAllister Posted August 29, 2013 Share Posted August 29, 2013 If you knew the diameter or radius the easy way is to double click on the circle tool in the tool palette. It will bring up the circle creation dialog where you can enter x,y and r/d. When you click ok the circle will be placed. But I suspect what you're actually asking for is an all inclusive solution. It could be done with a Vectorscript which asked for x,y and circumference and then called the circle tool. It could be built as a loop with an exit if you needed to do many in a row. Kevin Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted September 3, 2013 Vectorworks, Inc Employee Share Posted September 3, 2013 Select circle tool by radius > click on center > press tab > type your perimeter followed by /2/3.1416 > press enter That should do it Quote Link to comment
geoform Posted September 4, 2013 Share Posted September 4, 2013 Actually, it's even simpler than that: Just click to start your circle (in radius mode) then enter your circumference remembering to enter your unit mark (" or ') and then enter the forward slash to divide, and finally 6.28 (2 pi) so if you had a tree with a 36" circumference DBH it'd look like this 36"/6.28 Then just hit enter to lock in the length No need to hit TAB at any time if you're just working with Length (it's the first entry and by default anything you type after clicking once to start your circle will automatically be entered in the "L". or... You could use the existing tree tool in Landmark, then enter the DBH in the Object Info Pallette (using M5d's formula to yield diameter instead of radius) or just place all the trees first, then go back in and select each tree and enter the data. J Quote Link to comment
Mark Taylor Posted December 3, 2013 Author Share Posted December 3, 2013 Such a simple programming fix. Maybe for VectorWorks 2020. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted December 3, 2013 Vectorworks, Inc Employee Share Posted December 3, 2013 Did the answers above not work for you, or there is something else you want Vectorworks to be able to do that wasn't addressed? Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted December 4, 2013 Vectorworks, Inc Employee Share Posted December 4, 2013 The Reshaper Vectorworks Plug-in from Raymond Mullin (at Sirius Solutions) can do it plus a whole lot more... Quote Link to comment
Mark Taylor Posted December 6, 2013 Author Share Posted December 6, 2013 Sure they work, but it would be a lot easier to just plug in the circumference. When I plot the existing trees on a project I measure the location and the circumference of each tree. I don't measure diameter because it isn't very accurate. It would be very convenient to just place the center of the circle and enter a value for C. So tabbing into the fields should provide three linked values R(adius) - which is currently L D(iameter) C(ircumference) Thanks! Quote Link to comment
M5d Posted December 6, 2013 Share Posted December 6, 2013 That's pretty much the suggestion above (editable circumference / input field), but it didn't raise a response. If Jim doesn't pick this up here, you should throw your request into the wish list forum. It would be a minor but useful addition. It can't hurt to have it listed. Quote Link to comment
