When selecting a wall to customize via Wall Preferences, each change can be implemented with a simple OK button on the bottom of the pane. But in closing, if you click the OK button on the bottom of the pane, as you did for all other choices, the wall dumps back to it's default style and your changes are lost. This is because you didn't click the Save Preferences as Wall Style way up in the upper right corner of the pane.
This jump in pattern, where OK saves and then OK doesn't save, needs correcting.
Please allow "OK" to bring up a dialog to save the wall to the job and while I'm at it, to place the wall in the user's custom wall folder so it will be there on the next job, not just this one, and if he or she doesn't have a folder already created, to create one.
The disconnect between customizing walls and saving walls to the users customized folder is needlessly wide, requiring going to the Resource Browser, digging up the wall you just created, finding Export and saving it in that process. It's a work around that needs to be streamlined.
But first I'd love for the Wall Preferences save function to be improved. OK?
Tom G.
Thanks.
Tom
2 answers to this question
