ossosso Posted August 12, 2013 Share Posted August 12, 2013 Hi everybody! I'm new in this forum, but I'm also new in Vectorworks. My target in this moment is to better apply UVW map to a model inside Vectorworks. In my workflow I model an object into Rhino and then import the .3dm inside Vectorworks. As we know a nurbs surface doesn't need unwrap process 'cause the surface yet has UV coordinates. But sometimes it isn't enough for a nice result, under this point of view Rhino offers the possibility to apply a common "Box / Cylinder / Sphere" uvwmap to the object, overwriting the normal UV surface coordinates. When I export the .3dm this feature isn't saved in the file and so Vectorworks open the model with normal uv coordinates. I simply want to know if inside Vectorworks is possible to apply a Box/Cylinder/Sphere uvwmap. Thanks a lot! Quote Link to comment
