Force Object to Class Attributes
Hi does anyone know how to force objects to class attributes? I have tried turning on and off the 'use at creation' command but this does not work.
I have imported a complex DWG from a consultant and want to control the graphics, but the objects are not set to class attributes. It would take forever for me to go through the thousands of symbols andchange everything manually.
Cheers for the help!
(VW2012)
I think you should try "Tools/Utilities/Change Symbol Attrs..."
I just played around with a symbol and modified it's colors, and this tool seemed to accomplish what you are trying to achieve (I think.)I made sure to select the "Use the document's current default attributes".
You could knock all the acad symbols to their own folder, to better control the outcome.
good luck!
The Edit Class should do it. If it did not pick up the objects inside symbols and other containers, you may have to edit the class two more times. First time, uncheck the Use at Creation, and click OK to dismiss the dialog. Then edit the class again and check the Use at Creation. When you click OK, you should get a dialog with option to set all objects in the class - choose Yes, or Yes to All.
In my sample the gold circle is in my Test class and is contained in a symbol with the green circle. It took the class attributes and turned blue after checking the Yes, or the Yes to All option.
-B
Edited by Benson Shaw
