mpkeane Posted August 5, 2013 Share Posted August 5, 2013 I understand how to import a new plant symbol using the Resource Browser from the Plant Object file into the VW file I am working on. But how do I make that new plant symbol a default symbol so it will be available in all future VW files instead of just the one I am working on now? Marc Quote Link to comment
Jonathan Pickup Posted August 6, 2013 Share Posted August 6, 2013 Store the plant in the correct folder (Plants) in your user folder or Workgroup folder. Quote Link to comment
mpkeane Posted August 12, 2013 Author Share Posted August 12, 2013 When I import a new plant symbol, I go to the Resource Browser, right-click (mac) on a plant symbol, choose Import, and a new window opens called Import Symbol(s). In the new window there are two radio buttons: Preserve Folder Hierarchy and Select Destination Folder. If I choose the former the destination is fixed. If I choose the latter, the only choice I am given is the file I am actually working on at that time. Nowhere do I see how I could choose the User folder or Workgroup folder. How can I select that as a destination folder? Marc Quote Link to comment
Jonathan Pickup Posted August 13, 2013 Share Posted August 13, 2013 you can select your user folder or workgroup folder when you export plants, not when you import them. I suggest you try working through the getting started guides from Vectorworks. http://www.vectorworks.net/training/getting-started-guides/landmark/index.html you could also try getting a good manual on landmark: http://www.vectorworks.net/guides/Vectorworks-Landmark-Tutorial-Manual Quote Link to comment
mpkeane Posted August 13, 2013 Author Share Posted August 13, 2013 Thank you for the links. Actually I have watched all the Landmark video tutorials and also checked the Knowledge Base and also Vectorworks help. I found nothing that addressed this issue in the first two, and in VW help I found this: To export resources: 1. In the Resource Browser, select the resource(s) to export. 2. Select Export from the Resources menu. However, when I select a resource in the Resource Browser and then go to the Resources menu, there are 6 choices: View As; Show Object Types; Find Resource; New Resource in...(file name); Import; and Reference. There is no "Export" choice available. Is there a different Resource Browser somewhere else that has Export? (I am trying to export plant symbols from Plant Objects in the Resource browser to my User Folder so they will be always available in my Plant tool.) Marc Quote Link to comment
mpkeane Posted August 13, 2013 Author Share Posted August 13, 2013 OK. I see. Answered my own question. In order to Export, one needs to open the Resource file found in the Vectorworks folder > Libraries > ..... One can Export when the Resource file is opened, and Import when the Working file is opened. Quote Link to comment
