Bruce Kieffer Posted August 2, 2013 Share Posted August 2, 2013 Can this be done in one step after selecting the two lines? I'd like to join two non-touching lines together and have VW add the third line that joins them. Quote Link to comment
CipesDesign Posted August 2, 2013 Share Posted August 2, 2013 Select the lines, Command J... Quote Link to comment
Bruce Kieffer Posted August 2, 2013 Author Share Posted August 2, 2013 Peter, I just tried it and it works. I tried it last night and it didn't work. I did reboot VW this morning, maybe that solved the joining. I will test some more. Thanks for the help. Quote Link to comment
Bruce Kieffer Posted August 2, 2013 Author Share Posted August 2, 2013 I found why it doesn't work... I'm trying to join more than two lines. Anyway to get that to work? Quote Link to comment
Bruce Kieffer Posted August 2, 2013 Author Share Posted August 2, 2013 Sometimes the join function does not work on two lines. These lines where created from a "convert copy to lines" function. The error message is "Join operation could not be preformed." Not helpful at all. OK VW, you have some reason why you won't join my lines, why not help me and tell me what that reason is so I can fix it! Quote Link to comment
CipesDesign Posted August 3, 2013 Share Posted August 3, 2013 You should try the Connect/Combine Tool. It has various Modes. Mess around with it a little and I'll bet you can find something that works! Quote Link to comment
Bruce Kieffer Posted August 3, 2013 Author Share Posted August 3, 2013 Peter, That does seem better for what I'm doing. Thanks. Quote Link to comment
Bruce Kieffer Posted August 3, 2013 Author Share Posted August 3, 2013 Is there a way to click add click add? I have a series of lines who?s ends don't meet. The Connect/Combine tool makes me click too many times. I want to click two segments to join them, then one click to add another to the already combined segments and continue one clicking to add more segments. None of the tool modes seem to do that. Quote Link to comment
bc Posted August 3, 2013 Share Posted August 3, 2013 Hey Bruce, what the heck are you drawing anyway? Quote Link to comment
michaelk Posted August 3, 2013 Share Posted August 3, 2013 Bruce With a single click on a third line, how would it know which end of the line to join to which end of the line/polygon? mk Quote Link to comment
VincentCuclair Posted August 3, 2013 Share Posted August 3, 2013 Is there a way to click add click add? I have a series of lines who?s ends don't meet. The Connect/Combine tool makes me click too many times. I want to click two segments to join them, then one click to add another to the already combined segments and continue one clicking to add more segments. None of the tool modes seem to do that. If you hold down the Alt/Opt key you can join/trim several lines to one in one go.... Quote Link to comment
Bruce Kieffer Posted August 3, 2013 Author Share Posted August 3, 2013 Hey Bruce, what the heck are you drawing anyway? I'm illustrating a book of outdoor projects. All need to be Illustrator final art. I'm converting my VW files, cleaning them up in VW, and then exporting to AI. All the joining is done to clean up things before going to AI. Quote Link to comment
Bruce Kieffer Posted August 3, 2013 Author Share Posted August 3, 2013 Bruce With a single click on a third line, how would it know which end of the line to join to which end of the line/polygon? mk I would want it to join the closest end. Macromedia FreeHand was great at this task. Just select a mess of lines and say join. 95% of time the results were exactly what I wanted. RIP FreeHand! Quote Link to comment
Bruce Kieffer Posted August 3, 2013 Author Share Posted August 3, 2013 If you hold down the Alt/Opt key you can join/trim several lines to one in one go.... Final got this to work. The trick is you have to have all the lines selected first, then be in the Connect/Combine tool's first mode, and then click the first and last line. They all join! Quote Link to comment
