MERV Posted July 24, 2013 Share Posted July 24, 2013 Good morning, I have searched the forum for an hour, but found no specific answer yet. Is there a simple way to modify the 90-degree corner of a wall to give it a slightly rounded profile, similar to what you would achieve by adding a rounded pvc corner bead profile? Needs to modify a Wall component, not 2d geometry. Thanks all, Quote Link to comment
taoist Posted July 24, 2013 Share Posted July 24, 2013 I would suggest Wall sculpting as a way. http://kbase.vectorworks.net/questions/748/Creating+Sculpted+Walls i do not know of a way to separate the wall components to do what you suggest. Others might know of a way Quote Link to comment
Bob-H Posted July 24, 2013 Share Posted July 24, 2013 The way I would do it is to make a pillar with the same depth as the walls at the corner. Then just modify the 2D poly defining the pillar to have the rounded corner. Quote Link to comment
taoist Posted July 24, 2013 Share Posted July 24, 2013 How about using a filleted extrusion that matches the component height? Quote Link to comment
