I'm not really accustomed to using referenced DLVs in vectorworks having always used the design layer import method. However, I'm now working with some files that have been set up using DLVs.
I've been trying to export these files as DWGs to send to consultants and keep ending up with the referenced viewport information missing in the resultant file. I've tried deleting the references - choosing the option to import the info which appears to work until exporting, but again the resulting re-imported file is lacking the referenced VP info. Also tried checking the 'save reference cache to disk' option, but this makes no difference either.
Apologies if this is a topic previously covered, I searched the forum and did not find a solution.
Would be grateful for any suggestions. System setup and version info should be in the signature below.
HCO
Hi,
Best regards
HCO
Edited by HCOLink to comment
1 answer to this question
