jfmarch Posted July 15, 2013 Share Posted July 15, 2013 (edited) I recall there used to be an option for overhead door PIO's where you could set it to either sectional or coiling, which effects the extent of the dashed lines overhead. Is this still around? Thank you. Edited July 15, 2013 by jfmarch Quote Link to comment
taoist Posted July 15, 2013 Share Posted July 15, 2013 I do not see it in the OIP. What about using Part Line styles? Quote Link to comment
jfmarch Posted July 15, 2013 Author Share Posted July 15, 2013 That seems to only control the line type of the overhear door extension. What I am looking for is a way to reduce the depth of the dashed extension- while a section door would extend a the full door height when open, a coiling door would have a much smaller rectangle above... Quote Link to comment
taoist Posted July 15, 2013 Share Posted July 15, 2013 Maybe someone knows a way to do what you are asking. What version had the option you are describing? Quote Link to comment
jfmarch Posted July 15, 2013 Author Share Posted July 15, 2013 Since we upgrade each year, I'd be hard pressed to remember, but it was within the past 4 years... Quote Link to comment
taoist Posted July 16, 2013 Share Posted July 16, 2013 Do you still have the previous versions installed? Quote Link to comment
jfmarch Posted July 16, 2013 Author Share Posted July 16, 2013 No- only 2013. Takes up too much space.. Quote Link to comment
