taoist Posted July 13, 2013 Share Posted July 13, 2013 Is it possible to select more than one wall class for framing. I have exterior and interior walls in different classes. EX: Int-2x4-insul gwb, Ext-2x4-siding gwb When using wall framer under options button, need to select class using New button. Can't seem to select more than one wall class to frame. This makes the 3D model incomplete. Any ideas? Quote Link to comment
atari2600 Posted July 15, 2013 Share Posted July 15, 2013 Don't remember the last time I used it, but is it possible to use the command twice, select the interior walls first, then select the exterior walls next. I know it's a "workaround", but I don't recall the command is that sophisticated. Matt Quote Link to comment
