Ran Posted June 30, 2013 Share Posted June 30, 2013 (edited) Suggestions would be appreciated. I am a VW novice and I am attempting my first 3D. I have a cube like object which sides do not line up with x & y axis. I want to make another couple of extrudes to make the object taper down to one of the faces. I can not get the extrude to run along the objects own axis. I have made the same shape successfully with a NURB but the NURB will not subtract from another extrude solid which is my end intention. Hope someone can make sense of this. Struggling. Ran Edited June 30, 2013 by Ran Quote Link to comment
Kevin McAllister Posted June 30, 2013 Share Posted June 30, 2013 Ran, I have three suggestions that may help you - - draw and extrude the object while aligned to the x & y axis and then rotate it into place. - if the object needs to taper, try a tapered extrude or a multiple extrude with more than one profile shape. - if you've already made the object as a group of NURBS surfaces you can use Model>3D Power Pack>Stitch and Trim Surfaces to make it into a solid. If your NURBS are only curves, convert them to surfaces first Model>3D Power Pack>Create Surface From Curves. If you're still having trouble post an image or a file containing your object so we understand more clearly what you're trying to do. Kevin Quote Link to comment
Ran Posted July 2, 2013 Author Share Posted July 2, 2013 Thanks Kevin. The tapered extrude and rotating into place sorted the issue. Ran Quote Link to comment
