Kristen
Arrowhead - change size
If I have a line with an arrow endpoint (was part of a callout that was ungrouped, or copied from a VW8 leader line) how can I change the size of the arrowhead? Or do I have to redraw it?
Also, is there a setting to get marker lines on both sides of the callout note?
[ 10-02-2002, 10:55 AM: Message edited by: Kristen ]
Kristen,
You can select the line, go to the attributes palette, click on the arrows to bring up a drop down box and select Edit. After entering in the values for new arrowhead style, click on OK. The lines selected will use the specified arrow head settings.
Also, you cannot add a marker to both ends of a callout line. If you ungroup it so you have the single line, you can add an arrow to both ends of that line.
Thank you, Katie!
Could you add that to the wish list -- an option to have markers on both sides of the callout? We often use that when a note applies to a surrounding area.
I just discovered that there's a class setting for marker-head style and size... so that's what that column in class organization is for! Very handy.
