WR-Studio Posted June 15, 2013 Share Posted June 15, 2013 i have a phased project with an apartment and main home. i need separate window schedules for each. I used the window schedule resource available via the Tools>Reports>VA Create Schedule>Window Schedule Summarized command. i created and formatted the schedule. some windows are the same type in the apartment and main home. i classified the windows as "A-GLAZ-APT" in the apartment and "A-GLAZ-HOME" in the main home. i tried adding the "class" criteria, but receive syntax errors how do I filter one schedule to display the main home windows only and filter another schedule for the apartment windows only? Quote Link to comment
michaelk Posted June 16, 2013 Share Posted June 16, 2013 (edited) Where are you getting syntax errors? The criteria should look like this: The criteria can be in any order... Example attached hth mk Edited June 16, 2013 by michaelk Quote Link to comment
WR-Studio Posted June 20, 2013 Author Share Posted June 20, 2013 michaelk, thank you for sharing the criteria and sample. i mistakenly pasted the criteria into one of the columns. if i paste this criteria in the "ID" "No." or "Qty" column, I get the code instead of the result (see image) I reviewed your worksheet and noticed you didn't have to paste the criteria in a cell to get the result i want. how do i apply the criteria to the worksheet without pasting it into a cell? Quote Link to comment
michaelk Posted June 20, 2013 Share Posted June 20, 2013 Apply the criteria to the database rows. 1. click on the little triangle 2. In the pulldown choose Database Headers 3. Right click on the header database header row. (It will be the whole number row above the x.1, x.2.... rows.) 4. In the flyout choose Edit Criteria That will get you to the GUI. Click on the triangle again and click on Database Headers to get ride of the header row. hth mk Quote Link to comment
WR-Studio Posted June 22, 2013 Author Share Posted June 22, 2013 michaelk, yes, that was the problem. I tried to enter the command directly into the cell when I needed to use the database header row. I noticed another problem. I read about it previously in a thread, but couldn't find it this time. The door schedule has a quantity column. If it shows more than 1 item, the width or height column multiples the door width by the quantity. I used the "/C4" operand at the end of the equation so the Width column now reads "=((Door.Width)/C4)" (see attached) I thought that would divide the width by the quantity and correctly display the width for a single window. What is the right syntax to get the correct width? Quote Link to comment
WR-Studio Posted June 23, 2013 Author Share Posted June 23, 2013 michaelk, i figured it out. i dragged the "sum" button to the Width and Height columns. Now it correctly shows a single width instead of a collective width. hopefully, this will help others who experience the same problem. Quote Link to comment
michaelk Posted June 23, 2013 Share Posted June 23, 2013 Yep, you found it. I don't know why xxx/COUNT doesn't work... mk Quote Link to comment
