mjsmithvt Posted June 13, 2013 Share Posted June 13, 2013 I just started using the walls and doors command and I am trying to set up the reflected ceiling plan. I understand that you are to turn off the sills class and turn on the ceiling main class to begin the rcp. But when I do that the door frame is still visible. The door swing goes away when I hide the sills class but the frame remains. I went through all the class visibilities tied to the door and none of them appear to control the frame visibility in top/plan mode. Is their a way to turn off the frame (without turning the door class off because then the ceiling main class also disappears) so that when I have the ceiling main class turned on all I see are wall lines over the opening? Mike Quote Link to comment
genie Posted June 18, 2013 Share Posted June 18, 2013 Hi Mike, Unfortunately the plug-in object does not classify the jambs separately, so you can't turn off the jambs as you described. FW Quote Link to comment
RickR Posted June 21, 2013 Share Posted June 21, 2013 This needs to get added to the wish list. (again?) I've either added hatches in viewport annotation or copied walls to another class and deleted the doors and windows. Not very satisfying solutions. Quote Link to comment
