print / pdf multiple sheets at once
Is there a way to easily print and/or pdf multiple sheets in one step, instead of having to go to each sheet and do file > print separately ?
Also at the moment to pdf (on a mac) im going to file > print > pdf, is that the correct way using the inbuilt mac pdf printer (you can also download these for windows). Or should it be done under file > export ?
Edited by LLI Design
If you only have Fundamentals, you can set up one single Sheet layer viewport but under the printer settings and set the page size multiple sheets.
Since our office only deals with small projects (residential remodeling), this is how we have set up our projects for many years now. We have single sheet layers for the different printers we use (or sheet sizes.)
I'd be happy to go into more detail if you are interested.
