Sam Lee Posted June 6, 2013 Share Posted June 6, 2013 (edited) Is there a way to easily print and/or pdf multiple sheets in one step, instead of having to go to each sheet and do file > print separately ? Also at the moment to pdf (on a mac) im going to file > print > pdf, is that the correct way using the inbuilt mac pdf printer (you can also download these for windows). Or should it be done under file > export ? Edited June 6, 2013 by LLI Design Quote Link to comment
mar schrammeyer Posted June 6, 2013 Share Posted June 6, 2013 file/export/batch pdf Quote Link to comment
Kevin McAllister Posted June 6, 2013 Share Posted June 6, 2013 PLease add a signature detailing your version of VW and the system you're running it on (at the top of this page under My Stuff). If you're running Fundamentals I'm not sure that you have the batch PDF or batch print functions. Kevin Quote Link to comment
atari2600 Posted June 6, 2013 Share Posted June 6, 2013 If you only have Fundamentals, you can set up one single Sheet layer viewport but under the printer settings and set the page size multiple sheets. Since our office only deals with small projects (residential remodeling), this is how we have set up our projects for many years now. We have single sheet layers for the different printers we use (or sheet sizes.) I'd be happy to go into more detail if you are interested. Quote Link to comment
