VvierA Posted June 4, 2013 Share Posted June 4, 2013 Hello, I programmed a custom made "space" tool. It's a 2D path object. It's a room stamp and it retrieves the area (and perimeter) of the 2D path and writes it into a database. The space tool then places a room stamp symbol that is linked to the database. The strange thing is: If I use the space tool in the view area of a sheet layer everything is ok first. But if I move the view area on the sheet all the placed room stamps disappear. I can make them reappear by selecting and editing the polyline. Is there a bug in my script or is it a VW problem? Can anybody help? Thank you kind regards VvierA Script (you need a database called "db_raumdaten" and the fields "raumflaeche" and "raumumfang". You also need a symbol that is linked to the database fields and the symbol needs to be selected as a parameter of the PIO) PROCEDURE dballesstempel; CONST kObjXPropSpecialEdit = 3; {das erste Konstantenpaket dient dem 'event enabler' gem. http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=176863#Post176863} kReshapeSpecialEdit = 3; kObjXIs2DSurfaceEligible = 14; kObjXPropEditGroup = 1; kObjXPropEditGroupPath = 2; kObjOnInitXProperties = 5; kResetEventID = 3; feldSTRflaeche = 'raumflaeche'; feldSTRumfang = 'raumumfang'; datenbankSTR = 'db_raumdaten'; VAR theEvent, theButton :LONGINT; status :BOOLEAN; result :BOOLEAN; polyHand, objHand, recHand, wallHand, pathHand, dupeHand, symbHand, layerhandle :HANDLE; objName, symName, flaecheSTR, umfangSTR, par_raumbezeichnung, recordname, pioclass, flaeche_korrigSTR, rundungSTR :STRING; flaeche, umfang, flaeche_korrig, flaeche_korrekt, p1X,p1Y,p2X,p2Y,symbscale, layerscale: REAL; stempelpos :VECTOR; BEGIN vsoGetEventInfo(theEvent, theButton); CASE theEvent OF kObjOnInitXProperties: BEGIN status:=SetObjPropCharVS(kObjXPropSpecialEdit,Chr(kReshapeSpecialEdit)); status:=SetObjPropVS(kObjXIs2DSurfaceEligible,TRUE); status:=SetObjPropCharVS(kObjXPropEditGroup,Chr(kObjXPropEditGroupPath)); status:=vsoInsertAllParams; END; kResetEventID: {Hier beginnt der eigentlich Code f?r das Duplizieren des Polygons und das Einf?gen des Raumstempelsymbols} BEGIN IF GetCustomObjectInfo(objName, objHand, recHand, wallHand) THEN BEGIN pathHand := GetCustomObjectPath(objHand); pioclass := GetClass(objHand); dupeHand := CreateDuplicateObject(pathHand, objHand); SetClass(dupeHand,pioclass); SetPolyClosed(dupeHand, TRUE); stempelpos := GetPtInPoly(dupeHand); {Schwerpunkt des Polygons finden und in Vector speichern} flaeche := ObjAreaN(dupeHand); {Feststellung der Fl?che} flaeche_korrig := ppar_flaeche_korrig; {?bernahme des Korrekturwunschs aus den Parametern} flaeche_korrekt := flaeche+flaeche_korrig; umfang := HPerimN(dupeHand); {Feststellung des Umfangs} flaeche_korrigSTR := Num2Str(2,flaeche_korrig); {Korrekturfl?che wird in String umgewandelt, damit sie in die Datenbank gepatcht werden kann} flaecheSTR := Num2Str(-2,flaeche_korrekt); umfangSTR := Num2Str(2,umfang); {verwandelt Zahl in String - eine Voraussetzung zur Eintragung in die Datenbank} {Message('Fl?che ', flaeche, 'Fl?cheSTR', flaecheSTR);} {Kontrollausgabe der Fl?chen} symName :=ppar_symb; {?bernahme des Symbolnamens aus den Parametern} {symbol(symName, stempelpos.x, stempelpos.y,0);} IF ((pControlPoint01X=0) AND (pControlPoint01Y=0)) THEN {Ein manuelles Setzen der Kontrollpunkte auf 0 soll ein Reset der Position des Raumstempels in die Polygonmitte zur Folge haben} BEGIN {resultstatus := GetCustomObjectInfo(objectName, objectHand, recordHand, wallHand);} symbol(symName, stempelpos.x, stempelpos.y,ppar_dreh); symbHand := LNewObj; {HScale2D(symbHand, pControlPoint01X, pControlPoint01Y, ppar_scale, ppar_scale, TRUE);} recordname := GetName(recHand); SetRField(objHand,recordname,'ControlPoint01X',Num2Str(9,stempelpos.x)); SetRField(objHand,recordname,'ControlPoint01Y',Num2Str(9,stempelpos.y)); {Message('Objekthandle ',objHand,'recordname ',recordname,' Kontrollpunkt ', pControlPoint01X,' ', pControlPoint01Y,' ',stempelpos.x,' ',stempelpos.y);} {Kontrollausgabe der Symbolbreite} END ELSE BEGIN symbol(symName, pControlPoint01X, pControlPoint01Y,ppar_dreh); {symbHand := LNewObj;} {HScale2D(symbHand, pControlPoint01X, pControlPoint01Y, ppar_scale, ppar_scale, TRUE);} {SetSelect(LNewObj);} {Scale(ppar_scale,ppar_scale);} END; symbHand := LNewObj; layerHandle := ActLayer; {Handle f?r aktiven Layer abfragen} layerScale := GetLScale( layerHandle ); {Layer Scale abfragen} SetObjectVariableInt(symbHand,101,2); {Symbol auf symmetrische Skalierung setzen} symbscale := (ppar_scale*layerScale); {Ma?stab des Layers mit manueller Skalierung multiplizieren} SetObjectVariableReal(symbHand,102,symbscale); SetObjectVariableReal(symbHand,103,symbscale); {Message('Objekthandle ',symbHand,'symbscale ',symbscale);} {SetSelect(LNewObj);} {Scale(ppar_scale,ppar_scale);} {ScaleObjectN(symbHand,0,0,1,1);} {Symbol skalieren} {GetBBox(symbHand,p1X,p1Y,p2X,p2Y);} {Bounding Box des Symbols ermitteln} {Message('Koordinaten ', p1X,' ',p1Y,' ',p2X,' ',p2Y)}; {Kontrollausgabe der Symbolbreite} SetRField(symbHand, datenbankStr, feldSTRflaeche, flaecheSTR); SetRField(symbHand, datenbankStr, feldSTRumfang, umfangSTR); SetRField(symbHand, datenbankStr, 'raumnummer', ppar_raumnummer); SetRField(symbHand, datenbankStr, 'raumbezeichnung', ppar_raumbezeichnung); SetRField(symbHand, datenbankStr, 'bodenbelag', ppar_bodenbelag); SetRField(symbHand, datenbankStr, 'ukrd', ppar_ukrd); SetRField(symbHand, datenbankStr, 'ukfd', ppar_ukfd); SetRField(symbHand, datenbankStr, 'okffb', ppar_okffb); SetRField(symbHand, datenbankStr, 'okrfb', ppar_okrfb); SetRField(symbHand, datenbankStr, 'raumkategorie', ppar_raumkategorie); SetRField(symbHand, datenbankStr, 'raum_ehem', ppar_raum_ehem); SetRField(symbHand, datenbankStr, 'neu_bestand_umbau', ppar_modi); SetRField(symbHand, datenbankStr, 'flaeche_korrektur', flaeche_korrigSTR); END; END; END; END; Run(dballesstempel); Quote Link to comment
VvierA Posted June 4, 2013 Author Share Posted June 4, 2013 Maybe I found a hint how to solve the problem. It seems to me, that recalculating the PIO makes the room stamp reappear. It's a workaround to invoke the recalculation by editing the polyline of the PIO or editing a parameter. But that's annoying. I checked the options "Recalculate by event, by movement and by rotation" in the PIO options dialog but VW does not recognize the movement of the view area as a movement that invokes the recalculation. Is there a script to force all placed PIOs to recalculate. So I don't have to do it manually? Quote Link to comment
Miguel Barrera Posted June 4, 2013 Share Posted June 4, 2013 You need to create an event loop in order to take advantage of the recalculation by movement. Only when the object is moved, you should call the ResetObject function to regenerate the pio. If you add this function to your code above, it will go into an infinite loop and crash. Quote Link to comment
VvierA Posted June 4, 2013 Author Share Posted June 4, 2013 Thank you very much. Although I made the script earlier (with lots of help from you) I am still a beginner and do not know how to create an event loop or call the ResetObject function. Do you know some sort of sample or reference code so maybe I can adapt it for my purposes? That would be really great. But anyway - thank you very much for your help so far. VvierA Quote Link to comment
Miguel Barrera Posted June 6, 2013 Share Posted June 6, 2013 For an explanation of the event loop in VS: VS event programming To find what type of event was invoked: Parametric State Notifications Quote Link to comment
