Spooky Problem with self-made space tool...
Hello,
I programmed a custom made "space" tool. It's a 2D path object.
It's a room stamp and it retrieves the area (and perimeter) of the 2D path and writes it into a database. The space tool then places a room stamp symbol that is linked to the database.
The strange thing is:
If I use the space tool in the view area of a sheet layer everything is ok first.
But if I move the view area on the sheet all the placed room stamps disappear.
I can make them reappear by selecting and editing the polyline.
Is there a bug in my script or is it a VW problem?
Can anybody help?
Thank you
kind regards
VvierA
Script (you need a database called "db_raumdaten" and the fields "raumflaeche" and "raumumfang". You also need a symbol that is linked to the database fields and the symbol needs to be selected as a parameter of the PIO)
PROCEDURE dballesstempel;
CONST
kObjXPropSpecialEdit = 3; {das erste Konstantenpaket dient dem 'event enabler' gem. http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=176863#Post176863}
kReshapeSpecialEdit = 3;
kObjXIs2DSurfaceEligible = 14;
kObjXPropEditGroup = 1;
kObjXPropEditGroupPath = 2;
kObjOnInitXProperties = 5;
kResetEventID = 3;
feldSTRflaeche = 'raumflaeche';
feldSTRumfang = 'raumumfang';
datenbankSTR = 'db_raumdaten';
VAR
theEvent, theButton :LONGINT;
status :BOOLEAN;
result :BOOLEAN;
polyHand, objHand, recHand, wallHand, pathHand, dupeHand, symbHand, layerhandle :HANDLE;
objName, symName, flaecheSTR, umfangSTR, par_raumbezeichnung, recordname, pioclass, flaeche_korrigSTR, rundungSTR :STRING;
flaeche, umfang, flaeche_korrig, flaeche_korrekt, p1X,p1Y,p2X,p2Y,symbscale, layerscale: REAL;
stempelpos :VECTOR;
BEGIN
vsoGetEventInfo(theEvent, theButton);
CASE theEvent OF
kObjOnInitXProperties:
BEGIN
status:=SetObjPropCharVS(kObjXPropSpecialEdit,Chr(kReshapeSpecialEdit));
status:=SetObjPropVS(kObjXIs2DSurfaceEligible,TRUE);
status:=SetObjPropCharVS(kObjXPropEditGroup,Chr(kObjXPropEditGroupPath));
status:=vsoInsertAllParams;
END;
kResetEventID:
{Hier beginnt der eigentlich Code f?r das Duplizieren des Polygons und das Einf?gen des Raumstempelsymbols}
BEGIN
IF GetCustomObjectInfo(objName, objHand, recHand, wallHand) THEN
BEGIN
pathHand := GetCustomObjectPath(objHand);
pioclass := GetClass(objHand);
dupeHand := CreateDuplicateObject(pathHand, objHand);
SetClass(dupeHand,pioclass);
SetPolyClosed(dupeHand, TRUE);
stempelpos := GetPtInPoly(dupeHand); {Schwerpunkt des Polygons finden und in Vector speichern}
flaeche := ObjAreaN(dupeHand); {Feststellung der Fl?che}
flaeche_korrig := ppar_flaeche_korrig; {?bernahme des Korrekturwunschs aus den Parametern}
flaeche_korrekt := flaeche+flaeche_korrig;
umfang := HPerimN(dupeHand); {Feststellung des Umfangs}
flaeche_korrigSTR := Num2Str(2,flaeche_korrig); {Korrekturfl?che wird in String umgewandelt, damit sie in die Datenbank gepatcht werden kann}
flaecheSTR := Num2Str(-2,flaeche_korrekt);
umfangSTR := Num2Str(2,umfang); {verwandelt Zahl in String - eine Voraussetzung zur Eintragung in die Datenbank}
{Message('Fl?che ', flaeche, 'Fl?cheSTR', flaecheSTR);} {Kontrollausgabe der Fl?chen}
symName :=ppar_symb; {?bernahme des Symbolnamens aus den Parametern}
{symbol(symName, stempelpos.x, stempelpos.y,0);}
IF ((pControlPoint01X=0) AND (pControlPoint01Y=0)) THEN {Ein manuelles Setzen der Kontrollpunkte auf 0 soll ein Reset der Position des Raumstempels in die Polygonmitte zur Folge haben}
BEGIN
{resultstatus := GetCustomObjectInfo(objectName, objectHand, recordHand, wallHand);}
symbol(symName, stempelpos.x, stempelpos.y,ppar_dreh);
symbHand := LNewObj;
{HScale2D(symbHand, pControlPoint01X, pControlPoint01Y, ppar_scale, ppar_scale, TRUE);}
recordname := GetName(recHand);
SetRField(objHand,recordname,'ControlPoint01X',Num2Str(9,stempelpos.x));
SetRField(objHand,recordname,'ControlPoint01Y',Num2Str(9,stempelpos.y));
{Message('Objekthandle ',objHand,'recordname ',recordname,' Kontrollpunkt ', pControlPoint01X,' ', pControlPoint01Y,' ',stempelpos.x,' ',stempelpos.y);} {Kontrollausgabe der Symbolbreite}
END
ELSE BEGIN
symbol(symName, pControlPoint01X, pControlPoint01Y,ppar_dreh);
{symbHand := LNewObj;}
{SetSelect(LNewObj);}
{Scale(ppar_scale,ppar_scale);}
END;
layerHandle := ActLayer; {Handle f?r aktiven Layer abfragen}
layerScale := GetLScale( layerHandle ); {Layer Scale abfragen}
SetObjectVariableInt(symbHand,101,2); {Symbol auf symmetrische Skalierung setzen}
symbscale := (ppar_scale*layerScale); {Ma?stab des Layers mit manueller Skalierung multiplizieren}
SetObjectVariableReal(symbHand,102,symbscale);
SetObjectVariableReal(symbHand,103,symbscale);
{Message('Objekthandle ',symbHand,'symbscale ',symbscale);}
{ScaleObjectN(symbHand,0,0,1,1);} {Symbol skalieren}
{GetBBox(symbHand,p1X,p1Y,p2X,p2Y);} {Bounding Box des Symbols ermitteln}
{Message('Koordinaten ', p1X,' ',p1Y,' ',p2X,' ',p2Y)}; {Kontrollausgabe der Symbolbreite}
SetRField(symbHand, datenbankStr, feldSTRflaeche, flaecheSTR);
SetRField(symbHand, datenbankStr, feldSTRumfang, umfangSTR);
SetRField(symbHand, datenbankStr, 'raumnummer', ppar_raumnummer);
SetRField(symbHand, datenbankStr, 'raumbezeichnung', ppar_raumbezeichnung);
SetRField(symbHand, datenbankStr, 'bodenbelag', ppar_bodenbelag);
SetRField(symbHand, datenbankStr, 'ukrd', ppar_ukrd);
SetRField(symbHand, datenbankStr, 'ukfd', ppar_ukfd);
SetRField(symbHand, datenbankStr, 'okffb', ppar_okffb);
SetRField(symbHand, datenbankStr, 'okrfb', ppar_okrfb);
SetRField(symbHand, datenbankStr, 'raumkategorie', ppar_raumkategorie);
SetRField(symbHand, datenbankStr, 'raum_ehem', ppar_raum_ehem);
SetRField(symbHand, datenbankStr, 'neu_bestand_umbau', ppar_modi);
SetRField(symbHand, datenbankStr, 'flaeche_korrektur', flaeche_korrigSTR);
END;
END;
END;
END;
Run(dballesstempel);
Maybe I found a hint how to solve the problem.
It seems to me, that recalculating the PIO makes the room stamp reappear.
It's a workaround to invoke the recalculation by editing the polyline of the PIO or editing a parameter. But that's annoying.
I checked the options "Recalculate by event, by movement and by rotation" in the PIO options dialog but VW does not recognize the movement of the view area as a movement that invokes the recalculation.
Is there a script to force all placed PIOs to recalculate. So I don't have to do it manually?
Thank you very much.
Although I made the script earlier (with lots of help from you) I am still a beginner and do not know how to create an event loop or call the ResetObject function.
Do you know some sort of sample or reference code so maybe I can adapt it for my purposes? That would be really great.
But anyway - thank you very much for your help so far.
VvierA
