TiTaNiuM sAMuRai
Data Entry didja know
In the PIO box, entering text in the Leader or Trailer fields of a dimension object is not actually entered if the next thing one clicks on is the 'Show Dim Value' checkbox. Hitting Enter, Return, Tab, clicking anywhere else (afaik) accepts the entered text, but not on the checkbox. Why?
THe Show Dim Value is there to let you decide if you want VW to put the length in based on what you drew, or if you want to put it in yourself.
Checkmark Shwo Dim Value -- VW puts the dimension value on the screen as you drew the object and append anything you enter in the leader or trailer to what is already on the screen.
Removing the checkmark from the Show Dim Values box allows you to override what the real dimension of the object is, and type in whatever you want for leader or trailer.
If you have a box that is 10" long and you don't care what it looks like - and know you want it to read 11.5", remove the checkmark and type in 11.5" in either the trailer or leader box.
If you have a box that is 10" long, and you really want the dimension to read " This square is 10.5" long", then leave the checkmark box checked, for the leader type in "This square is" and in the trailer type in ".5" long ".
rolleyes.gif" border="0
yes, I know what the fields and boxes are FOR. With that in mind, please re-read my post. After typing in text to either field, one must do something to make it appear in the dimension. One can hit Enter, Return, or Tab, or one can click anywhere in the drawing, or somewhere on a toolbar. However, if one clicks on the checkbox, the entered data is NOT recognized. There is no run-through of an idle user input loop -- which updates the display, and which would explain the twitchy tape measure tool -- before the checkbox's functions are called.
TSI don't understand what you are saying. If you checkmark the Show Dim value, the dimension is displayed and the inforamtion added in leadera nd or trailer is APPENDED and shows that way.
If you don't checkmark the box, ONLY what is typed in leader and or trailer is shown.
Is that not what you are getting?
1. Make a constrained dim. Keep it selected.
2. Type something in the Leader field. Do not hit enter.
3. Click on the checkbox.
Now, tell me: does the text that you entered, appear on screen? Does it even remain in the field?
I selected a dimension. The show dim value checkmark box is checked.
I enter 123 abc in the leader box.
Do not hit enter
remove the checkmark in the checkmark box.
123 abc shows on the dimension.
I do the same for trailer ..
same results.
Huh.
That's bizarre.
Let me look into this. On my g4, os 10.1.5 it works fine too. I'll see if I can track down a G3.
(no, I wasn't tabbing back and forth .. )
I see your problem now.
When you remove the checkmark from Show Dim Value it's resetting the Leader and Trailer default boxes.
I'll bug list it.
Looks like you'll have to remove the checkmark first, then enter your criteria in.
interesting that this is now a bug!
i've always had this problem but thought i was just the way it had to be, more of a quirk in the process.
G4 - OS 9.2.2 - VW9.5.2
It's only on the mac platform for whatever reason.
It is buglisted now.
Interesting (assuming you weren't alt-tabbing to-from explorer/netscape to read the directions).
VW9.5.2 on MacOSX.1.5, iMac G3.
I followed your directions, and clicking on the box cleared the field, with nothing subsequently showing on the dim line.
