alfresco Posted April 30, 2013 Share Posted April 30, 2013 I am working on a project with a site model. There only appears to one site model in the project. However, when I insert plant material, I get a pop up box where I can select either site model or site model-1? I cannot not seem to find any duplication, and cannot change the name of the site model?s Any suggestions, Thanks/ lm Quote Link to comment
CipesDesign Posted April 30, 2013 Share Posted April 30, 2013 Did you try Selecting one Site Model then Moving it a known distance, to see if there's another dupe hiding underneath?? You might also try Custom Selection then use the little selection toggles to try to see where each is located... Quote Link to comment
alfresco Posted May 1, 2013 Author Share Posted May 1, 2013 Peter, I have attempted to check to determine where the duplicate is located. I have even deleted the site model and recreated it. I am getting an message regarding invalid data. However I cannot determine what is corrupt or incorrectly selected. All staked objects seem to be correct and are the only objects that are selected to create the site model. The mystery continues. Thanks Quote Link to comment
ottoLejeune Posted May 1, 2013 Share Posted May 1, 2013 Try copying your site model to a blank / new file.... then insert the plant material and see if the same issue pops up? That may help narrow it down.... Also... (in a copy file)... delete the site plan and try inserting the plant material... Same issue? Quote Link to comment
