Bruce Kieffer
Door Question
Bruce,
Click on the door you inserted to select it.
In the Object Info Palette, click on the flip button till you get desired position
See image
Edited by taoist
The flip on a door object is only available if the door is inserted into a wall. You can however Modify > Rotate > Flip Horizontal or Flip Vertical
If you mean show the direction of the door in an elevation view, that's OIP > Settings > 3D Visualization > Show Interior / Exterior Marker
But, knowing the kind of drawing you do, you might mean "show decorative hinges in 3D". If that's the case, I think you need to model the whole shebang.
mk
Yes, the door is not in a wall, and rotate/flip horizontal does work. I keep looking of the darn flip button! And yes MK, I do want "real" hinges. I added them by jamming them, and I added miter lines in the corners of the casing (trim).
On 12/5/2018 at 3:44 AM, Interior Obsession said:
Plz, share some images of the actual location.
Sorry, this was posted in 2013.
