zuken86 Posted April 18, 2013 Share Posted April 18, 2013 Is there a shortcut in Mac to switch between Screen Plane and Layer Plane mode? Thanks, Quote Link to comment
GWS Posted April 18, 2013 Share Posted April 18, 2013 No, as far as I'm aware there isn't. There should be though, in fact the layer/screen plane really needs sorting out Quote Link to comment
PeterT Posted April 23, 2013 Share Posted April 23, 2013 You want something easier than just selecting the plane mode from the "Active Plane" pulldown in the view bar? Quote Link to comment
pgym Posted April 24, 2013 Share Posted April 24, 2013 You want something easier than just selecting the plane mode from the "Active Plane" pulldown in the view bar? I don't know about you, but I can hit a keyboard shortcut a helluva lot quicker than I can move the mouse pointer to the pulldown, click-drag to the desired plane mode, release the mouse button, and move the pointer back to where I left off, so, yes, a keyboard shortcut is a lot easier than changing the plane via a pulldown in the view bar, so, yes, I DO want something easier than selecting plane mode from the pulldown in the view bar. Quote Link to comment
Monadnoc Posted April 25, 2013 Share Posted April 25, 2013 (edited) I agree. Keyboard shortcuts are way quicker, and having to slide up to a pulldown is a pain if you do it a lot. Especially if you use a very large monitor (I use a 46 inch HDTV as my main monitor, and often I would have to be sliding the cursor over 1 or 2 FEET of screen). It's all about efficiency. Every single click you can eliminate, every needless cursor movement you can remove, and every time you don't have to stop and read between two choices and select one of them, is very important to a well thought out interface. All those things are no longer a priority to VW programmers, in fact I don't think they even consider them when designing a command or tool. But I wish they would go back to the old ways and make them priorities. And I know I'm beating a dead horse. Still gonna beat it though. Edited April 25, 2013 by Monadnoc Quote Link to comment
Jonathan Pickup Posted April 25, 2013 Share Posted April 25, 2013 We have a hot key to toggle automatic working plane, so why not one for screen plane? I like this wish. Quote Link to comment
Jonathan Pickup Posted April 25, 2013 Share Posted April 25, 2013 (edited) Screen Plane/Working Plane is a Vectorworks preference, and you can create a script for a palette, or you can make it into a menu so that you can add a keyboard shortcut. Edited April 25, 2013 by Jonathan Pickup Quote Link to comment
sle7en7 Posted July 31, 2015 Share Posted July 31, 2015 What about shortcut between sheet layers and design layers? Is there a shortcut to shift back and fort between layers? Quote Link to comment
michaelk Posted July 31, 2015 Share Posted July 31, 2015 Command-Shift-Up Arrow and Command-Shift-Down Arrow indexes through design and sheet layers. mk Quote Link to comment
