CREATING 1'0" 3-D DOMES
Just create a hemisphere of radius 25'. Then shell it using Shell Solid Tool using a thickness of 1' and selecting the bottom cap (be careful to select the bottom cap as the selection of the spherical face and botom cap looks the same). You can also create another hemisphere of 24' and subtract from the larger hemisphere. Then go to the front view or some such view where you see the elevation of the hemisphere and split the hemisphere using a line 10' below the topmost point of the hemisphere - you may need to construct a locus or a line for this step.
