MattG Posted April 16, 2013 Share Posted April 16, 2013 Has anyone come up with a solution for applying a label legend to a 3D only lighting device? I am working on a project with a number of curves that from a front view are making a frown. I am showing the lights in 3d and curving with the truss. I am using a 3D only symbol. However as soon as I apply a legend vectorworks wants to think it is a hybrid symbol and I can see my containers, but not the 3D symbol. I want to see the containers and the 3D symbol. I'm not sure if anyone has a option or thought for this. I have had similar situations in the past and I wound up making dummy lighting devices and just leaving the 3D symbols as symbols and not devices and applying the actual information to a dummy symbol that may of only been a 2D loci. However this gets really old really fast. Matt Quote Link to comment
michaelk Posted April 16, 2013 Share Posted April 16, 2013 You can't have a 3D only spotlight instrument with a label legend. As you found, the label legend is 2D and creates a hybrid symbol. Have you tried using the parts database so you can set the 3D orientation in the OIP? mk Quote Link to comment
MattG Posted April 16, 2013 Author Share Posted April 16, 2013 I understand the parts database and do not care for that. We do a lot of custom/unique things. It is often easier to just use the 3D symbol and rotate them opposed to editing all my symbols to meet the necessary criteria in the parts database. Also when you do something where trusses are at odd angles I will often build them in plan view and rotate in the appropriate view. This would be a pain to constantly adjust fixtures individually. Quote Link to comment
