Bruce Kieffer Posted April 12, 2013 Share Posted April 12, 2013 Is it possible to create an exterior door that swings out using the door tool? Quote Link to comment
P Retondo Posted April 12, 2013 Share Posted April 12, 2013 Bruce, I'm not sure I understand your question, so this may not be the answer you're looking for - all doors swings can be put into the 4 potential configurations using the "Flip" button in the OIP. Quote Link to comment
Bruce Kieffer Posted April 12, 2013 Author Share Posted April 12, 2013 Peter, Let me explain further. I spoke with tech support this morning and learned that since my door is not in a wall, then I won't see the flip button in the OIP. I think the work around would be to flip the door around, and put interior trim on instead of exterior trim. It looks like the threshold is symmetrical, so that is not a problem (that I can tell so far). Quote Link to comment
Jim Smith Posted April 12, 2013 Share Posted April 12, 2013 Bruce, what if you put the door in an unstyled wall, the wall was only as wide as the door frame, in a hidden class & had a height of zero? Quote Link to comment
Tom G. Posted April 12, 2013 Share Posted April 12, 2013 Use a Virtual Wall? It's invisible. Tom Quote Link to comment
Bruce Kieffer Posted April 12, 2013 Author Share Posted April 12, 2013 Sounds like you and Jim are saying the same thing. Sounds like a good idea. Quote Link to comment
