Pen Sizes/Line Thickness
Marc
Interested to know what line thicknesses people are using out there.
I'm just using a crapy little epson on a4 size paper and I get no difference from .03mm to .15mmanyways I found a cool website that explains the whole paper size issue thing. It's a little hard to find the part about pen sizes so here's what he recomends:
.13.18.25.35.50.70it's all sq rt of 2 stuff.Hope it helps hope it's interesting.I'm trying to make this link work! arggggg
[ 09-15-2002: Message edited by: Marc ]=http://www.cl.cam.ac.uk/~mgk25/iso-paper.html]web page
http://www.cl.ac.uk/~mgk25/iso-paper.html
.07, .13, .25, .50, 1.0 mm
I like having line weights that are 1:2, so perceptibly different (for architectural drawing).
The printer: HP430. The manual says .13mm is the smallest line, but in fact it gives a lighter line also, the .07mm, just by thinning out the dots I suppose.
similar website:
http://www.archivebuilders.com/aba006.html
- Carl
[ 09-15-2002: Message edited by: Carl Burns ]
Finally it worked.Anyways... the whole reason about the sq root of 2 is that when you reduce or enlarge you will have equivalent line weights.
That is to say if you are drawing with say a .13 on A4 and you enlarge to A3 you can keep drawing with .18 and so on.
Later skatersM
