File properties and location
So i've opened a file from my recent files list and i want to bring up the file properties from within the file. I've been through all the menu options and there is not (as far as i can see) any document/file properties option to bring up.
How do i find out where this file is located?
Sorry, noob here. Is this a script or a plugin? Not sure what to do with it.
It's a function that should be placed in a script to load the filepath.
Paste the example as stated on the website into a script, compile and run it. Doubleclicking that script should show the current filename and path in the vw message box.
PROCEDURE Example;
BEGIN
  Message(GetFPathName);
END;
RUN(Example);
