Access vertex of a 2D object
Is there a fuction to or predefined procedure to access each vertex point of a 2D object in Vectorscript? I want to insert a custom symbol at each vertex of a rectangle. Thanks!
If your rectangle or any figure was drawn with a path object it would be possible. With a handle to the object you can retrieve the "path" and loop over each vertexpoint.
The standard rectangle has no path
