PeterT Posted September 13, 2002 Share Posted September 13, 2002 Why is it when running VW 8.5.2 in OS X Classic Mode I get a "switch to wire frame mode" message every time I try to nudge something? This occurs when I am already in wire frame mode, and in top plan view. If I re-select wire frame mode anyway, it knocks me into orthagonal projection, then I have to re-select 2D plan projection, then I can nudge. I am also getting a "re-render or switch to wire frame" dialog every time I enter or exit a group, and sometimes when I choose a sheet from the saved sheets menu. What is up with this? PeterT Quote Link to comment
Guest Posted September 16, 2002 Share Posted September 16, 2002 You should only be getting that message if the drawing is currently rendered. To my recollection, there weren't any bugs in VW 8.5.2 in regards to this problem. What version of OS 10 are you using? Quote Link to comment
PeterT Posted September 16, 2002 Author Share Posted September 16, 2002 Katie, We are running OS 10.1.5. and we are working entirely in 2-D. (i.e. no light objects, and no rendering) This does not happen with any specific file, but seems to be randomly happening to most files. Actually, we are also having same problem in OS X native running VW 9.5.2. My co-worker just exemplified it for me on his machine( G4 800 Mhz, OS 10.1.5, VW 9.5.2). He selected an object, tried to nudge with shift/ arrow and nothing moved, he then immediatly chose a sheet from the choose sheet pull up menu, and got the " re-render all layers or switch to wireframe" dialog. I thought it might have something to do with our custom workspace, which is common to both versions of Vectorworks, but after switching to the "Standard" Workspace, my co-worker tried choosing a sheet and still got the re-render dialog. I can not figure this one out. Please help, Peter Quote Link to comment
Matthew Giampapa Posted September 16, 2002 Share Posted September 16, 2002 Peter, It sounds like you have saved the sheet in a rendered view like hidden line. (somthing that will not be visualy apparent on a 2D drawing) Switch to the sheet that is having the problems, switch to wireframe mode and then re-save the sheet and delete the original sheet. Quote Link to comment
