Jason-Baeri Posted April 3, 2013 Share Posted April 3, 2013 Hi all, When I try to open the label legend manager, I get the following slew of errors: Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Array ALLOCATE dimension not an INTEGER value: _316 Warning: _2369 _315 - Value will not fit in an integer. Warning: _2369 _315 - Value will not fit in an integer. Error: _2369 _315 - Index outside array limits. It's only happening with one file so I know it's file related, I just can't figure out what it's related to or how to get rid of it. Anybody have any ideas? thanks, JB Quote Link to comment
