Unnijv
Modify circles
Is it possible to modify a circle by removing parts of it so that I get 3/4 of a circle left for instance? I have tried out the arc, but I do not get the result I want
yup, draw a circle, the use a polygon to clip the parts off you dont want, under the modify menu
You can also do it with an arc and two lines.
- Draw a 270? arc.
- Draw lines from the arc centre to each of the arc ends.
- Select the arc and both lines and then Compose.
- Result will be a Polyline object.
