  • 1
Wall Styles - Vertical stacking of wall components
taoist
This is something we should have had some time ago.
Currently, there is no way within a wall style to vertically stack components.
Example: Lower half of exterior wall to be stone veneer, upper half to be siding.
This is very common in residential construction.
2 answers to this question
R___t is not the only software that will do this.
There are others that will also allow you to select what material the wall components consist of and allow you place the horizontal and vertical positions of the material and whether or not to report it in the material reports.
Also allow you to profile walls. Think canted walls as a simple illustration.
VW is behind the times as we know.
