Alan H
How do you align roof & wall render textures?
I thought that these would align automatically, but they don't.
Would appreciate any help on this. See attached image.
anyone able to help, or point to thread if this has previously discussed (i can't seem to find any thanks)?
It is the same render texture applied to both the wall and roof
In the Render Tab of the OIP is a way to adjust the Texture Orientation. Try changing the Horiz. or Vert. Offset value and watch the texture move. See attached. Note: you need to be looking at the correct "Part" of the object (e.g.: Top of the Roof, or Left/Right Side of a Wall). Note 2: If you have rotated the texture, horizontal becomes vertical, and visa-versa.
Thanks Peter
I am still struggling with this, just to note it is the roof element I want move to match with the walls.
If I am looking at the wall elevation and adjust the offset values on the roof nothing seems to happen.
If I look at the roof face plane and adjust the offset values nothing seems to happen either.
Can you think of anything that i would be doing wrong?
Select the Roof; Go to the Render Tab in the OIP; Make sure the the Part=Top in the parts pulldown; if your texture has been rotated 90? (which I think might be the case) then you need to adjust the Vertical Offset value. If not rotated then the Horizontal should do it... Try adjusting 2-3" at a time. You should be able to see the change each time the model re-renders...
I wasn't in the top mode !
Thank you very much again for taking the time to explain, it is very much appreciated.
