doug shaffer 2 Posted March 4, 2013 Hello - Twice today, VW2013 has frozen my iMac to a point where it can not force quit anything. The clock gets stuck on the time of the crash, and I have to hold down the power button to re-start. Anyone else experiencing this? Any suggestions on what to do about it? Quote Share this post Link to post
CipesDesign 153 Posted March 4, 2013 Any clues as to what type and size of file you were working on at the time? Quote Share this post Link to post
michaelk 539 Posted March 5, 2013 Check the crash logs and/or keep activity monitor running. There might be another application or process that is conflicting w/ VW. (I had problems a while ago with old adobe extensions(?) plug-ins(?) -- things -- that were causing crashes. hth mk Quote Share this post Link to post
doug shaffer 2 Posted March 5, 2013 Thanks for your response, CipesDesign. The file is about 39MB and I am pretty sure that it was first created in version 2012. I am using VW Architect walls, window and door PIOs, etc. but not for 3D use. Quote Share this post Link to post
doug shaffer 2 Posted March 5, 2013 Thanks, michaelk. Where would I find a crash log, and how I "keep activity monitor running"? I noticed that Adobe is trying to automatically install the latest version of Reader and I've been ignoring it. Perhaps this is related? Quote Share this post Link to post
michaelk 539 Posted March 5, 2013 (edited) I'm the wrong person to answer a question about log files! I called Apple when I was having problems and they talked me through it. My computer sent them the logs while I was on the phone and they found the problem right away. It might be this one: Apple Menu > About This Mac > More Info... > System Report > Software/Logs There are also logs in ~Library/Logs/CrashReporter ... The name of this file has changed in recent versions. I don't have 10.8 yet, so I don't know for sure where it is. VW tech support may be able to help. I think there are some known apps that conflict with VW. Activity Monitor is a cool little application in the Application/Utilities folder that will monitor all your cpu processes (among many other things). You may see something sneaking up the list before a crash. Edited March 5, 2013 by michaelk Quote Share this post Link to post
D Wood 1 Posted March 6, 2013 Doug I doubt Adobe Reader will cause problems, the latest version is good and useful. Quote Share this post Link to post
doug shaffer 2 Posted June 6, 2013 I continue to have crashes that bring down my whole system. And there is no particular sequence of events that leads to the crash, but it only happens when I'm using Vectorworks. I'll simply moving my cursor, and half way across the window, it will freeze. Other seemingly innocuous actions lead to freezes, too. I've enquired about this on this forum and the other more official looking one, and haven't been able to find a solution. To be fair, we have another computer with the exact same specs in the office that is not having this problem, so it's possible that it's just my particular installation, or perhaps the file that I'm working on. Both of the machines used Migration Assistant to transfer information from old to new computers. After talking with tech support, I promise to never to do that again. It would be VERY cumbersome to recreate the file and probably easier to re-install vectorworks. Is there anything I need to be concerned about if I do this? Quote Share this post Link to post
grant_PD 254 Posted June 6, 2013 Does it only happen on a single file? Or all and any files? Quote Share this post Link to post
doug shaffer 2 Posted June 6, 2013 Unfortunately, I'm not sure... I have been working on only one project for quite some time now. It contains a bunch of references, viewports, annotations, etc.. I presume that there is not a fast way of recreating a complex file? Thanks - Quote Share this post Link to post
Yoginathaswami 0 Posted June 7, 2013 Aloha, Doug: Try running disk permissions repair from the Disk Utility application. A lot of times corrupted permissions will cause various applications to run really sluggish or crash. Quote Share this post Link to post
doug shaffer 2 Posted June 7, 2013 Hello, Yoginathaswami - I've tried that each time I've had the problem. Perhaps it temporarily fixes the problem, but usually it crashes again within another week's time. The interesting thing is that I get the same permissions error every time. I don't recall exactly what it is, but it is something regarding Java and some some string of letters that should be another string of letters. Do you think it might have something to do with Java? Thanks, Quote Share this post Link to post
Yoginathaswami 0 Posted June 7, 2013 Hi, Doug: I am not sure if it is Java. However, it seems something from iMac's system or could be some other application installed triggering it. Specially when you have the same permission getting corrupted repeatedly. Do you recall installing any application before having this crash issue? It is one possible way to isolate the problem--as it is only happening on this iMac. Have tou tried booting the iMac on the "safe boot" mode and run the "fsck -fy" disk repair routine? If that doesn't solve it, you might want to contact Apple regarding the repeatedly corrupt permissions. Quote Share this post Link to post
VectorGeek 3 Posted June 7, 2013 Hi, Doug: I am not sure if it is Java. However, it seems something from iMac's system or could be some other application installed triggering it. Specially when you have the same permission getting corrupted repeatedly. Do you recall installing any application before having this crash issue? It is one possible way to isolate the problem--as it is only happening on this iMac. Have tou tried booting the iMac on the "safe boot" mode and run the "fsck -fy" disk repair routine? If that doesn't solve it, you might want to contact Apple regarding the repeatedly corrupt permissions. Or perhaps try disabling Java (there is a system preference in which you can do that) for a couple of weeks to see if things improve. V-G Vector "doesn't works sometimes" Works 2013 Mac OS X 10.7.4 Coleco Vision Pong 1.0 Quote Share this post Link to post
Bob-H 1 Posted June 9, 2013 The other thing to check would be the MacOSX System Preference panes. I've had some problems running Hyperdock and Default Folder, and turning them off seemed to limit the Vw13 crashes I had before. Quote Share this post Link to post
BillV 22 Posted June 9, 2013 I also have been having issues with VW crashing on 10.8. This occurs always when I attempt to do a batch print pdf. The crash occurs and VW does not generate a Crash Log. I have done the repair permissions, removed my VW preferences, moved my user folder and created a new one, validated and deleted duplicate fonts. You name it I have tried it! However, I finally created a new user account and ran VW under that account. The problem was solved. Quote Share this post Link to post
Yoginathaswami 0 Posted June 9, 2013 (edited) Hi, Vijay: that is good way to isolate the crash. But Doug would have to live with many other apps that might not work properly during the test period. Isolating the issue as Ian points is better solution in the long run. Bill: You solution to the crashing issue definitely points to corrupted user permission. I would try to run the "safe boot disk repair first" as it is much less time time compared to creating new user account and setting up everything again. (My two cents worth for Doug.) Edited June 9, 2013 by Yoginathaswami Quote Share this post Link to post
Vincent C 25 Posted June 10, 2013 Where would I find a crash log, Try HD>Programs>Utility programs>System messages>User diagnostic reports (or something, I'm using the swedish version so they might have slightly different names......) Quote Share this post Link to post
doug shaffer 2 Posted June 10, 2013 Thanks for everyone's responses. I'll try a few of these things and report back soon. Quote Share this post Link to post
BillV 22 Posted June 11, 2013 I picked this up today which may be relevant "In the July issue of Macworld, and on page 87 in the Bugs and Fixes column there is a piece on how Quick-Time components in various software could cause crashes of imaging software. Apparently there are Apple sandboxing restrictions on apps sold through the Apple App Store that could lead to these crashes with imaging software unaware of these restrictions. The remedy was to find the conflicts and delete or upgrade the software. To locate the conflicts it was suggested to download Sandbox Cleaner by boinx.com. It discovered a conflict with Flip4Mac Flip Player. Sand Box's scan suggested upgrading it which I did. Then tried the operations that crashed Vectorworks and everything is now stable." This did not fix my problem but it did fix another I had encountered on OS 10.8.3 which was share screen on Skype which did not work until I installed new Flip Mac 4. Ironically Skype support could not fix it but since they are owned by Microsoft that's hardly surprising! Quote Share this post Link to post
Bruce Kieffer 167 Posted June 14, 2013 I've had crashing with some files when clicking the layers button in the top toolbar. It's a 10.8 problem. Tech support said they could not reproduce the problem and ask me to do a WHOLE MESS of trouble shooting. I and to ask three times if they were testing using OSX 10.8. Once they actually did so, then they confirmed the crashing. So I guess this means that 10.8 could have other system related issues with VW. Can you send the file to tech support and see if they can recreate the crashes? I know you said you would never do that again, and I understand your frustration since I've experienced the same many times, but if you hold your ground and make them do the work, things are better. You should never forget we are all beta testers. Quote Share this post Link to post
BillV 22 Posted July 4, 2013 Update on crashing on Batch Print PDF. I videoed the crashes and sent the offending file to NNA. The technicians were unable to replicate this, however we persevered and found the bug, which they are able to fix! Quote Share this post Link to post
