Kevin McAllister
Fix How Vectorworks Names Exported DWGs
Its the modern age of file names. Please fix Vectorworks so it doesn't shorten longer file names when exporting DWG files. Its frustrating to have to fix all the shortened names after the fact.
Kevin
3 answers to this question
This could actually be related to deficiencies in the dwg format (at least it was so in older versions)!?
Vincent, this may be true. It can certainly shorten the filename for exports of older DWGs flavours, as far as I know, there is no need with more current versions. It should retain the file name I give it. In my case, it truncates off the date because of my file naming convention. Its more of a problem to have an undated file....
Kevin
