UK terminology of fasteners
Christiaan
2 answers to this question
Agreed.
(Flat head screws are usually called countersunk in the UK, set screws are grub screws etc)
Placing fasteners on a working plane also needs improving. The workaround of clicking backwards and forwards between working planes is time consuming and even then you need to rotate the plane as the fastener is placed along the y-axis. Why not the z-axis as that is perpendicular to the working plane?
We should be able to use the 'automatic' plane option for fastener insertion.
