Jonathan Pickup Posted February 14, 2013 Share Posted February 14, 2013 if you are trying to import shape files, they are not in ASCII format. What command are you using to import the ASCII files? Quote Link to comment
Utectok Posted February 15, 2013 Author Share Posted February 15, 2013 (edited) Hi Jonathan just bought ur book nice one! No there are ASCII files in the open source OS contour survey data. I'm trying a diffrent approach by importing the os surveys. They should import through import survey command I've been told but I get an error on line two note every time? Perhaps there is a header code needed in the file?? I'm at a loss :-/ Cheers Will Ps the advantage of this approach is I could have more data rather than loads of small google earth terrain clips that need fitting together. Edited February 15, 2013 by Utectok Quote Link to comment
Utectok Posted February 15, 2013 Author Share Posted February 15, 2013 (edited) Land-Form PANORAMA? Data type: Vector (Contours), Grid (DTM) Supply format: DXF [Contours], ASCII grid [DTM], NTF [DTM] Version: 04/2010 Note This product is supplied both as a set of contours and spot heights (Contours) and as a gridded digital terrain model (DTM). Panorama data was collected between 1970 and 1980. This product has not been updated since this date Edited February 15, 2013 by Utectok Quote Link to comment
Utectok Posted February 15, 2013 Author Share Posted February 15, 2013 Tried opening them in rhino too but nothing mind it was a beta version Quote Link to comment
Utectok Posted February 16, 2013 Author Share Posted February 16, 2013 Ok here is a rendering done via mapping the 3d polys (from google earth lochnagar hill in this case) with the 3d curve tool and creating a lofted surface and then project a solid on it split it into blocks etc etc rendered in Artlantis Quote Link to comment
Utectok Posted February 16, 2013 Author Share Posted February 16, 2013 This also can be done via create contours then loft surface then project to surface but the softening added by using the curve tool creates a better result as the contours follow the triangle polys to closely. I'm still having no luck importing ASCII data which would cut out the boring bit of sticking together all the little terrain maps from google earth. Quote Link to comment
Utectok Posted February 16, 2013 Author Share Posted February 16, 2013 Ohhh and thanks for all the help people !!! Quote Link to comment
