Paolo Posted August 29, 2002 Share Posted August 29, 2002 Suppose to insert two adjacent symbols (or parametric objects, e.g. 2 doors) in a wall (note, adjacent means that the second object left side starts from the first object rigth side). Doing this you expect should be no wall between the two objects, instead, in 3D mode, you'll see a zero thick (3D polygon) part of the wall. This happens even if you overlap the two objects. It seems that an object in a wall takes with him a frame of 3D polygons all around its perimeter. The question is: there is a way to get rid of this frame? Quote Link to comment
