jeffroyer
Texture on Wall Projections
Having difficulty assigning a texture to a wall projection.
The object that I created has its own texture when rendered in 3d. When it is added to the wall as a projection, it no longer renders with its texture.
I have "use object 3d attributes" checked in the dialogue box. When I double click the protrusion to go into edit mode, the edit mode renders with the proper texture. When I go back to the overall rendering, it no longer has its texture.
I noticed in Vectorworks Help that it states the object will render with its own FILL - which implies it will not use the texture.
It is always better and simpler to use a symbol instead of a wall projection. The wall projection object is a failed one...
Edited by DWorks
So sad. It had so much promise.
The beauty of the projection, if it could work, would be the possibility of representing varied materials on a continuous wall. The place I was trying to use it has windows and a door - so the openings become automatic.
My workaround is to break the wall into pieces - each with its own thickness and exterior material. Not very good.
Hello, I'm new to the forum!
I'm having this exact same problem and wondering if there is a way around this yet?
I'm modelling container conversions and creating the corrugated sides by drawing it in 2d and extruding it to the right height, I'm then drawing a wall behind it (with wall tool) and using the wall projection to join them together so I can position windows/doors easily but I then (as above) can not apply textures to the exterior wall face.
Maybe there is another way I can do this?
Thanks
Sometimes it's about using work-arounds rather than slogging away with the standard tools.
Assuming you want to have the wall projection in a different texture/colour just for the render/visual, whilst still maintaining your basic 2D layout ....
  • Would applying a decal to the wall in the correct position/texture provide the solution?
  • Would using the extract tool provide the shape for its own texture just a 'nudge' (to keep geometry apart) in front of your added wall feature?
There is a good 'how-to' of the technique with different finishes on walls here....
https://youtu.be/ppJ6Q4j8hi4
Wall projection is broken - has been for ages.
You can use an extrude or better still if it is just a shaft of some kind then just use a wall as you will be able to map the texture better.
Hi,
Thanks for your replies, I seem to have got round it for now by creating a wall recess rather than a projection as that still allows you to add a different texture to either side o the wall.
I'll have to do a bit more playing around with different way's of doing this but it seems to be working for now!
Thanks again.
