Worksheet Problem in 2012 / 2013
M5d
I'm moving to 2012 and can't get my existing worksheets from 2011 and earlier versions to function in 2012 or 2013. For energy efficiency calculations I pull data from spaces and windows for ventilation figures but database worksheet cells no longer seem able to do calculations based on the column head figures.
There's a stripped down worksheet in the attached file, the problem is in cell F4, if anyone would be willing to take a look.
Hi Juan, thanks for taking a look.
The attached files are exactly the same in their respective versions.
The 2011 version shows how the worksheet used to function, subsequent versions don't respond to the column sum function as they have previously.
I don't know if this is an intended change or a bug resulting from the unlimited sum functions they added in 2012.
If it's an intended change, interpreting data on worksheet rows is no longer possible.
