mattao Posted December 19, 2012 Share Posted December 19, 2012 Hi everyone, I've produced an heavy VW file and I use the new collapsible classes. I got classes such as 12 Tiles_Green_30x60 and 12 Tiles_Grey_30x30... I'd like to filter my worksheet by A PART of the class name... like all the classes containing 12 Tiles in there class name. Could you help? Thanks Quote Link to comment
michaelk Posted December 19, 2012 Share Posted December 19, 2012 If I understand what you are trying to do, then yes, you can. Create a database. For the criteria use Class = 12 Tiles_Green_30x60 + whatever other criteria you need. This will give you a database of just the objects in Class '12 Tiles_Green_30x60'. Right click on the database row header and choose Edit Critieria. In the next dialog box hit Cancel. The formula bar will now say =DATABASE(......... Look for the expression (C='12 Tiles_Green_30x60') Delete the part between the single quotes that changes in each class name and replace it with an asterisk. i.e., (C='12 Tiles_Green_*') Hit return. The database will now have all the objects who's class name contains 12 Tiles_Green_ If you edit the criteria again using the GUI you will need to reinsert the asterisk. example attached. hth mk Quote Link to comment
mattao Posted December 19, 2012 Author Share Posted December 19, 2012 Thanks for your real fast answer, BUT It's not working there, the criteria return 0 objects as soon as I hit "recalculate" I am now updating to SP2.... Quote Link to comment
michaelk Posted December 19, 2012 Share Posted December 19, 2012 If you want to post a stripped down example, I'd be happy to take a look at it. There's one way that it works and a million ways it doesn't! mk Quote Link to comment
mattao Posted December 19, 2012 Author Share Posted December 19, 2012 Ok it's now working... I updated to SP2 I will check for a huge file Thanks a lot for your help Quote Link to comment
mattao Posted December 19, 2012 Author Share Posted December 19, 2012 It's now perfectly working on a huge file too... :-) Very pleased Mat there Quote Link to comment
mattao Posted December 19, 2012 Author Share Posted December 19, 2012 May I suggest to VW developers to add a contain choice in the class CRITERIA? Quote Link to comment
mattao Posted December 20, 2012 Author Share Posted December 20, 2012 I noticed a very large difference between refreshing times of a worksheet when I change a criteria ( refresh instantly ) and ask for recalculate ( got the time to check for mail ) Is that normal? Plus: I'd like to have a shortcut to access the worksheet database criteria Quote Link to comment
