GWS Posted December 15, 2012 Share Posted December 15, 2012 (edited) I am trying to get a tile to repeat on a polygon using the surface array. Unfortunately I can't get it to lie on the polygon. The tile is repeated so that it is parallel to the ground plane. The file is 8.8Mb (even stripped down) Any help gratefully received Edited December 15, 2012 by GWS Quote Link to comment
Benson Shaw Posted December 15, 2012 Share Posted December 15, 2012 Is there an offset in the OIP which could be corrected? Maybe the array is moved off it's zero position because of some edit? Dbl click to edit the array, choose the Array Items option. A single instance of the arrayed object appears. Navigate to appropriate view and move the item by distance required. Unfortunately, the show other objects in edit mode does not work for this, so some guide objects or numeric data for the move are helpful. Or, just create new objects and array again. Dbl click the array, choose Base Object. Select the base object and copy to clipboard. Exit the array, Paste in Place to get a new base object. Select the base and the louver, Create Surface Array. Worked for me, anyway. -B Quote Link to comment
GWS Posted December 16, 2012 Author Share Posted December 16, 2012 Ah, I didn't think to double click on the array to get the edit dialogue box up. Thank you Benson from that point I was able to fix it. Quote Link to comment
Benson Shaw Posted December 17, 2012 Share Posted December 17, 2012 Guy - You are welcome. Glad it works with dbl click to Edit. All those years of using a single button Mac mouse, I never got the habit of right click. Anyway, right click is another way to get to the options for array Edit . -B Quote Link to comment
