P Retondo
Site pad with retaining edge madness
Does anyone have a handle on using pad with retaining edge with the "send to surface" command? From reading the documentation, I expect that the pad stays put and the retaining edge would go to the terrain surface. Sounds great, but I can't get anything to work. (Caveat, I am working with a site model originally created in v2012). When I select just the pad and go "send to surface," nothing happens. When I select the pad and the terrain model and go "send to surface," the pad and retaining edge don't move, and the whole site model moves down to some apparently random location. Pad is set to "modify proposed." Another caveat, I'm still working with SP1 until the WGR issue is resolved.
Did you remember to Update the Site Model? FWIW, I have not tried the operation you are attempting... But I have used a separate retaining wall/Pad to do the same thing..
Hi Peter, thanks, but don't you want to define the retaining edge BEFORE you update the site model? I'll try updating first and let you know if this works.
Later: what happens if you update first is the terrain is warped to meet the undesired pad location instead of cutting vertically down to the pad.
Edited by P Retondo
Pete, As far as I recall, changes (any changes) made to the Site Model require that the Model be Updated in order to see the results of the change(s)...
Peter, yes I'm aware. Jonathan, thanks for letting me know it works for you! Not working for me . . . something is screwy, maybe I have to start from scratch in 2013 and rebuild the darn thing. BTW, Jonathan, are you using SP2?
Having spoken to tech support, apparently this is a bug, supposedly fixed in SP2. But I'll have to wait for SP3 because of the problem in SP2 with work group referencing . . .
