Instances from surface array to cinema4d (c4d)
Hello Ilay:
VW symbols become C4D instance objects, so you should be able to get render instances if you use VW symbols.
In C4D's object browser you will see the first copy of the symbol, and the other copies should be shown as instance objects.
HTH
Hello Dave.
Thank you, i'm still self-learning vw.
If we are using surface array with trimmed edges - there are will be "Solid Intersection"-objects in c4d. So need to think where will be instances with overlap edges and or where will be solids/meshes.
Symbols exploded to solids/meshes when edges conditions are trim-option.
