Running Vector Scripts
Hi Jim,
The only way is to make them into a plug-in menu command, and then add each plug-in to your workspace. Then you can assign hot keys as you would for any other menu command.
I believe there is a description of the steps required somewhere in the forums if you search. Or perhaps someone can direct you there if they have it bookmarked.
It's not difficult - just takes a few minutes to follow the steps.
V-G
Member of the Knights Who Say "Ni!!"
