Hakman Posted November 25, 2012 Share Posted November 25, 2012 I wish this will be possible to do, rather than framing the whole Ext wall. unless it can be done, and I am not aware of it. Please advise... Quote Link to comment
CipesDesign Posted November 25, 2012 Share Posted November 25, 2012 Try this: Create a new Class ("frm'd walls", or sim.); assign that portion of the wall - that particular component - to the new class; in the Wall Fram Dialog select that class for framing. I'm not sure it will work, but it's worth a try. Quote Link to comment
Jonathan Pickup Posted November 25, 2012 Share Posted November 25, 2012 It is possible, if you turn off the classes of the other wall components Quote Link to comment
Hakman Posted November 25, 2012 Author Share Posted November 25, 2012 CipesDesign, That is what I have in the above attachement. Jonathan, Maybe you can show me an example, I can only select one class from the AEC/Framing/Wall Framer, so I selected the 2x4 framing part of the wall component, I get the above error. Quote Link to comment
Jonathan Pickup Posted November 25, 2012 Share Posted November 25, 2012 have you looked at the movies on my web site? http://learn.archoncad.com Quote Link to comment
Hakman Posted November 25, 2012 Author Share Posted November 25, 2012 Jonathan, Can you please provide me with the link on your website that deals with the above matter? Thank you, Quote Link to comment
Jonathan Pickup Posted November 25, 2012 Share Posted November 25, 2012 http://learn.archoncad.com/2012/11/10423/epodcast167-wall-framing-core-of-wall/ Quote Link to comment
Hakman Posted November 26, 2012 Author Share Posted November 26, 2012 Jonathan, Is it available at http://serviceselect.vectorworks.net ? Quote Link to comment
djb Posted November 27, 2012 Share Posted November 27, 2012 Just make a separate wall for the furring. Quote Link to comment
Hakman Posted November 27, 2012 Author Share Posted November 27, 2012 The problem with making a separate wall which I did, Windows and Doors will only go through the first wall it touch. I ended up doing that, and customize the framing after... Which is a lot of work when there are many doors and windows. See attached image Quote Link to comment
