Hippocode Posted November 21, 2012 Share Posted November 21, 2012 (edited) What I'm trying to achieve is a custom PIO that can be compared with the HVAC Straight Duct. Different from the Straight Duct is that I want it to be a polylone, so I can draw my ventilation way faster, including the corners. My idea was, to offset user defined path (2d path object) once left and once right. Then i'd try to add all the vertexes of the right new path to the left new path, so I can create a closed polygon wrapped around the user defined path. For some reason, I can only get the coordinates/vertices of the left OR the right offset, not both of them. Trying to add vertexes to the other fails horribly Any ideas ? { obtain a handle to the path polygon of the object } pathHd:= GetCustomObjectPath(objHd); { get the number of vertices in the path } num_vertices:= GetVertNum(pathHd); { draw the piping lines and text label } FOR i:= 1 TO num_vertices DO BEGIN GetPolylineVertex(pathHd, i, x, y, vertexType, vertexRadius); SetPolylineVertex(pathHd, i, x, y, 3, Afronding, TRUE); END; SetPolyClosed(pathHd, False); dupeHand := CreateDuplicateObject(pathHd, objHd); LeftOffsetHd:= OffsetPoly(dupeHand, 10, 1, False, False, 16, 1); RightOffsetHd:= OffsetPoly(dupeHand, -10, 1, False, False, 16, 1); FOR i:= 1 TO num_vertices DO BEGIN GetPolylineVertex(LeftOffsetHd, i, x, y, vertexType, vertexRadius); InsertVertex(RightOffsetHd,x,y,1,vertexType,vertexRadius); {Here I assume that because I add a vertex before the first one, this new vertex will be "number one"} END; Edited November 21, 2012 by hippothamus Quote Link to comment
