jstroming 1 Posted November 20, 2012 I have been using Vectorworks 2010 without issue on a Windows 7 64bit machine for a few years. About a week ago, I got an error message "Vectorworks 2010 Application has stopped working". Here are the details: Problem signature: Problem Event Name: APPCRASH Application Name: Vectorworks2010.exe Application Version: 15.0.2.0 Application Timestamp: 4b0e2827 Fault Module Name: StackHash_4c0d Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: 4c0d Additional Information 2: 4c0d4d78887f76d971d5d00f1f20a433 Additional Information 3: 4c0d Additional Information 4: 4c0d4d78887f76d971d5d00f1f20a433 Here is what I have tried: *Re-install Vectorworks *Re-install Quicktime from Vectorworks Install CD *Update quicktime to latest version *Reinstall video drivers *Update video drivers *Disable antivirus *Disconnect from Internet *Run program as Administrator from Program Files folder *Clean Boot Unfortunately I do not have a system restore point to go back to. Quote Share this post Link to post
0 Guest Jim Kelly Posted November 23, 2012 Have you tried updating to the latest Vectorworks service pack? http://www.vectorworks.net/downloads/ServicePack.php?major=2010&servicepack=4 Quote Share this post Link to post
0 jstroming 1 Posted November 24, 2012 Hi Jim, I tried the update, no luck. Same error message. But if it's worth anything I don't think I've ever updated Vectorworks. Should I have installed earlier SP's first? Quote Share this post Link to post
0 Guest Jim Kelly Posted November 25, 2012 I'd perhaps contact technical support directly. There are a series of applications known to interact poorly with Vectorworks, and I'd suspect perhaps you might be running one. Unfortunately I'm not aware of what those are, and they'd have the most up to date information. Quote Share this post Link to post
Problem signature:
Locale ID: 1033
*Disable antivirus
*Clean Boot
