Navigate to design layer
in VW 2008 Architect:
when on sheet, and double clicking on viewport, to edit the Design Layer, the "view" does not center on the area of the viewport. In other words, when I click to edit the design layer, the screen moves into the design layer, but to an area of the layer that is not where all my line work is located. Why is this? It seems to be related to the computer, not the file, but I am not completely sure of this. Can anyone offer a suggestion?
thanks.
Mathew - could this involve the Edit Viewport/Design Layer options? If the viewport is moved from its creation location, and the Display using VP Attributes option is not checked, the edit window will not center on the same view in the Design Layer.
If the Viewport was not moved after creation, that edit option should not be the problem.
Another thing to test is the Vectorworks Prefs>Display Tab>Center on Objects after View Change.
Dunno if either will solve, but it's something to look at.
-B
