FRED JOHNSON Posted August 14, 2002 Share Posted August 14, 2002 My dimension slash size & thickness is set up perfectly for a 1/4 scale plan drawing and works for larger details that require dimensions. However, at times, I have an 1/8 scale plan and the slashes are now too big. Is there a way of setting up a separate "1/8 scale dimension slash standard" to use on these occasions without having to change my 1/4 plan standard?? Quote Link to comment
PeterT Posted August 15, 2002 Share Posted August 15, 2002 Dimension slash thickness is a drawing preference, so within the same file you cannot have two different slash thicknesses. You could however set up different files with different slash thicknesses. It would be great if Nemetschek could put the slash thickness inside the dimension standards like all the other dimension settings, then you could set up a custom standard with a different slash thickness and use the two different standards in the same file. Quote Link to comment
FRED JOHNSON Posted August 15, 2002 Author Share Posted August 15, 2002 Peter, I guess you are right. I was trying to eliminate setting up a stationary document just for use with 1/8 scale plans but maybe this is the way to go. It is not something I need very often. Thanks for responding, Fred Quote Link to comment
